Revit 2019 - Rendering Background Style
rkonik
rkonik
When rendering a model, we have the background style set to Sky:Cloudy. When the rendering is complete, there are no clouds in the background.  Render the same model on different system, with same settings, the clouds appear. We have repaired the Revit installation on the system not rendering the clouds, as well as, uninstalled and reinstalled Revit. Still have the same issue after both installations.  We have attached a screen shot from each system, with the rendering settings, and the image from both systems.
kadmonkee
width setting and uncompressed image settings are different in both images
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
rkonik
Ended up contacting Autodesk Support. In the end, final solution was uninstalling and the reinstalling all the material libraries for Revit.
