Floor aligned to Imported cad contour
2 REPLIES 2
Cyril_Osano
185 Views, 2 Replies
Good day!
Is there anyone who knows the way to align a Floor to a imported contour?
Please see sample project below.
Thanks for the help!
2 REPLIES 2
pedruccioli
in reply to: Cyril_Osano
That should be done with Toposolid/Toposurface.
But if you need it to be a floor, you can use a Dynamo script to read the points of the toposurface (don't know how it goes on toposolids) and apply the contours as "Modify Sub Elements" automatically.
See this video: https://www.youtube.com/watch?v=PU1jeMYw2vM
Architecture Modelling, BIM Workflows and Information Exchange.
LinkedIn
If you can ID a point in the CAD Survey that is also in your Revit Project, you could use Specify Coordinates at Point in Revit and enter the x, y, z corrdinates of that ID'ed point into the N/S, E/W and Elevation Fields. Then Link the CAD via Shared Coordinates/Aligned.
Add'l info:
Help | Video: Use Geographic Data from a Linked DWG File | Autodesk
Forma Design Contest
