Hi, I've just went from Revit 2023 to 2024 and I'm finding an issue with importing certain PDF's. I get a message saying "The selected PDF (file name) is password protected and can't be opened". I have tried importing the exact same file into Revit 2023 and it works straight away.
Is there additional settings in Revit 2024 that I need to change to get it to work?
Have you tried opening the PDF and editing it to see if it is password protected in a PDF program?
PDF opens and doesn't need password to access. Strange why it works in 2023 version and not 2024.
The best way to open password-protected PDF files is to use the Softaken PDF Unlocker application. A few days ago, I too tried to figure out how to open PDF files. But it took me a few searches to locate this software. The feature of the PDF unlock tool to open many PDF files at once speeds up the opening process. This tool allows you to open PDF documents and remove passwords from them, and it operates with all Windows PCs. To see how the application succeeds, download the free trial version.
https://in.indeed.com/career-advice/career-development/how-to-remove-pdf-password
You can easily open password-protected PDF files and lock and unlock them. Use the pcinfotools PDF Unlocker program. Given the selected option, it is possible to swiftly and efficiently remove and secure password protection from one or more PDF files. To avoid printing, editing, and copying restrictions, this tool can protect your PDF file. Download the free trial version of the application to see how it functions. With Windows 11, 10, 8.1, 8, 7, Vista, XP, and earlier versions, the program runs properly.
If you want to open a password-protected PDF, the OSTtoPSTAPP PDF Open application can be ideal. This tool is easy to use and works well so users can remove passwords quickly. Upload the PDF file to the app, enter the password, and you’re ready to use this tool. Your PDF will open in minutes. Your information is safe with this tool as it follows strict security rules. You can easily access your important data when you use it.
Opening or editing password protected PDF files can be challenging at times, especially when you forget the password or have to enter it repeatedly. To solve this problem, you can use ToolsGround PDF Unlock Software. This software easily unlocks password protected PDF files, allowing you to access, copy or print documents without any interruption. Its specialty is that it is extremely simple to use and frees your PDF file from password in just a few minutes, without any data loss.
