Find Elements By Level
2 REPLIES 2
BigPicture045
192 Views, 2 Replies
I need to delete a level and I need to make sure there are no elements associated with that level. I have made a schedule with level, however, it does not list the level of most of the elements:
I have done the schedule method, however, the majority of the project elements are not displaying the level:
These are all associated with levels. Any suggestions to get their level to show up in the schedule or does this only work with particular elements?
2 REPLIES 2
Reference Level Parameter Field.
in reply to: BigPicture045
If you use scheduling methods than you need category specific schedules, not Multi-category schedule.  Then, you can add either Level or Reference Level depends on categories.
Another way if you don't have a lot of elements to check, you can create a 3d view > select the level and delete > Revit will highlight elements to be deleted and ask for your confirmation > you can see what and where they are.
Forma Design Contest
