I need to delete a level and I need to make sure there are no elements associated with that level. I have made a schedule with level, however, it does not list the level of most of the elements:
I have done the schedule method, however, the majority of the project elements are not displaying the level:
These are all associated with levels. Any suggestions to get their level to show up in the schedule or does this only work with particular elements?
Solved by ToanDN. Go to Solution.
If you use scheduling methods than you need category specific schedules, not Multi-category schedule. Then, you can add either Level or Reference Level depends on categories.
Another way if you don't have a lot of elements to check, you can create a 3d view > select the level and delete > Revit will highlight elements to be deleted and ask for your confirmation > you can see what and where they are.
