FILE NOT SAVED error Revit 2020
Message 1 of 33
I am a beginner with Revit, I downloaded 2020 and saving was working fine. Today getting this error "File Not Saved." Can someone tell me what to do ? I'm afraid to lose all my work. Thanks..
Replies (32)
Message 21 of 33
Yes I found the folder
Message 22 of 33
Any files in there with a RVT extension?
Message 23 of 33
No. Here is a screenshot
Message 24 of 33
From Revit, try and open the each of the two large files.
Message 25 of 33
This is the path from the journal folder
C:\Users\alexa\AppData\Local\Google\Chrome\User Data\Default
but when i go from revit there's no app data folder. i'm really so lost about to give up on this.
thanks for all the help.
Message 26 of 33
Will I lose all the families I downloaded into my model or will those still be there?
Message 27 of 33
No - not that folder.  After \local\ you need Autodesk - not chrome.
Message 28 of 33
okay oops C:\Users\alexa\AppData\Local\Autodesk\Revit\Autodesk Revit 2020\Journals
but either way once i get to user\alexa\ theres no app data folder that i can find
Message 29 of 33
Try and copy it and save it in a place that you can access.
Message 30 of 33
okay copied to desktop and opened new revit window, tried to open it but nothing even comes up at all. doesn't load or give error, just nothing.
Message 31 of 33
martijn_pater
I recall having this issue I think, but not exactly what it was. Your work thusfar might be lost for the day actually, hope not ofcourse but I'm afraid it might be... I am trying to remember what the issue was back when I encountered that...
Maybe it was that I opened the project from startscreen (local file), instead of opening the central file (w. create new local) from a network location... ? Something like that...
Message 32 of 33
Maybe its all lost Ive been spending all day and night trying to fix this, apparently can't even work from the old file at the same time .. have a deadline at 10am.
Do you remember if you fixed it or you just lost your work?
Message 33 of 33
I closed it and now the last back up file I see is time logged this morning but when I open it the file is before I even started working yesterday???
