FILE NOT SAVED error Revit 2020
Message 1 of 33
I am a beginner with Revit, I downloaded 2020 and saving was working fine. Today getting this error "File Not Saved." Can someone tell me what to do ? I'm afraid to lose all my work. Thanks..
Replies (32)
Message 2 of 33
Message 3 of 33
Are you sure you are not in "Viewer Mode"?  Maybe you need just to activate the software?
Message 4 of 33
I’m not sure how do I check viewer mode ?
Message 5 of 33
I was saving yesterday fine, I left it sitting open over night and this just started happening today
Message 6 of 33
ennujozlagam
do a clean uninstall and reinstall again, it could be some program files are corrupted..just saying. thanks
Message 7 of 33
Doesn’t that mean I’ll have to close my project and lose everything ? If that happens I’m going to have a panic attack.
Message 8 of 33
ennujozlagam
your file is still there in your harddrive to make safe copy the file to another folder. you just going to do a clean uninstall and reinstall again the program and see if helps. no need to have a panic attack..if persist see a doctor. lol hanks
Message 9 of 33
ennujozlagam
my suggestion in only a worse scenario if you cannot save your file, it's up to you to decide. thanks 😋
Message 10 of 33
Thanks for responding. Still a little confused, I can’t uninstall the program unless I close the window and if I close the window all my work will not be saved right ? Revit doesn’t do back up files right ? When I go to the file in the folder is shows it was last saved yesterday before I started working...
I checked my license and it’s fine, I’m on student version, also not in viewer mode. At this point I feel like I might as well just leave the file open forever and hope it never crashes
Message 11 of 33
ennujozlagam
if you try saveas to another filename, what happen? can saveas to another filename? thanks
you have two forum account? 🙄
Message 12 of 33
ennujozlagam
another options if you have any anti virus program installed in your computer i.e. mcafee try to switch off or uninstall first and reinstall later and see if helps. thnaks
Message 13 of 33
it won't let me.. the error pops up as soon as i hit save or save as..i tried to save to cloud also but when i click the option nothing happens. weird. i'm going to try your other suggestion now thanks
Message 14 of 33
uninstalled mcafee but still getting the error
Message 15 of 33
ennujozlagam
You have no choice but to restart your computer and forget all the things you have done, it's all the same in end part you continue to draw, you cannot save also the file??? Just saying.. restart and open again your file and see if can save or do a clean uninstall and reinstall again your Revit program. It's your decision to make. Good luck. Thanks
Message 16 of 33
Before reinstalling the software, try and open the journal file, which is a backup of the project.  Go to:
C:\Users\user\AppData\Local\Autodesk\Revit\Autodesk Revit 2020\Journals
and sort by date.  Open the latest file with a rvt extension.
Message 17 of 33
Hi thanks , I get an error saying cannot find. I tried to get to it manually and I can't find the path either.
Message 18 of 33
Could you find the relevant Journal folder?  Are there any files in there with a RVT extension?
Message 19 of 33
Ok I searched my whole PC for "journal" and some showed up with timestamps from last night which is good. But they are in text files? How would I open?
Message 20 of 33
Refer to post 16 which shows the path for the journal folder - are you in the correct one?
