Revit 2022
I want to focus on solving the first issue to prove to my colleague that it works before tackling the second...
Solved by ToanDN. Go to Solution.
Yes you can do it. See example below:
Differentiate Walls and Curtain Walls in the schedule. I use Assembly Description here as I already assigned them to my walls and curtain walls. You can use any applicable field such as Family, Type, etc...
Add Percentage parameter:
