Hey guys,
In my current model is a revit-topography which can be seen in the {3D} view in Revit. But when I open the same model in the autodesk viewer it is missing. What can I do about this?
Cheers,
Leonard
Hey guys,
Cheers,
Leonard
Solved by leonard.moelders. Go to Solution.
When you say "revit-topography", do you mean Toposurface? If so, is the Toposurface visible in the Default 3D View?
Yes I mean Toposurface and yes it is visible in the default 3D View (the view with the small house as shurtcut).
Is it a workshared file? If so, the default {3D} view has your username affixed to it.
Try this: open a copy of the model with Detach and discard worksets to create a non-work shared file, create a default {3D} view, save and upload this file.
It is a detached workshared-file and the visibility for topography is aktive for the default 3D-view.
Is the 3d view has your username in it?
No the name is "{3D}"
So I tried deleten all of the ~25 3D Views and created a new one. Then the whole model dissapeared in the viewer. Then I turned the topography-surface on in every 3D view and then it worked. So how can I know which one the viewer uses without checking this for all 25 3D views?
Delete all 3d views and recreate a new one {3D}.
@ToanDN schrieb:Delete all 3d views and recreate a new one {3D}.
Already tried and failed. But I found the solution. Its just a settings-issue for sharing. 🙂
And what would be the setting that fixes this issue?
