family system
2 REPLIES 2
469 Views, 2 Replies
family system
I have a problem with Revit Italy System Families for Revit 2016, I downloaded the student version but it doesn't download the system families. When I look for them in the folder C:\ProgramData\Autodesk\RVT 2016\Templates\Italy it's empty. How can I download them? As I don't have any system family such as doors, windows, contest ( people, tree...) etc
2 REPLIES 2
ennujozlagam
Hello, you may check it here. Thanks
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Mahmoud.Ziedan
Dear,
First of all,those families are called Autodesk default library note system families.Anyway if you want to redownload those families,go to add/remove software and then search for autodesk library,then click uninstall/modify,a panel will appear so you can select the library you want to download.
Kindly if this solved your issue mark as solution to help others
Your question got successfully answered? Then just click on the 'Mark as solution' button.
src="https://autodesk.widen.net/content/fbz0l2onhe/png/autodesk-expert-elite-forum-signature-logo.png" >
Mahmoud Zeidan
BIM Manager/Mechanical Engineer
Forma Design Contest
