Failed to specify the OmniClass parameter value of the family file
2 REPLIES 2
b10705001F2HWP
167 Views, 2 Replies
Hello, I would like to ask why the OmniClass parameter value in the family file cannot be changed? Or I can only select the number provided by Revit and cannot enter it manually?
But the value I want to specify is not in the OmniClass list provided by Revit. The OmniClass manual I refer to is this.
OmniClass
In addition, why the numbers provided in this txt are different from the OmniClass list provided by Revit?
And I found that when opening different family files, the OmniClass list provided by Revit will be different.
Tags (2)
2 REPLIES 2
Simon_Weel
in reply to: b10705001F2HWP
Modify the file?
b10705001F2HWP
in reply to: Simon_Weel
Modify the OmniClass parameter value in the family file.
I think I have found the problem, because I didn't update the taxonomy file associated with revit...
Thank you for your reply! 😃
Forma Design Contest
Technology Administrators
