Hello, I would like to ask why the OmniClass parameter value in the family file cannot be changed? Or I can only select the number provided by Revit and cannot enter it manually?
But the value I want to specify is not in the OmniClass list provided by Revit. The OmniClass manual I refer to is this.
OmniClass
In addition, why the numbers provided in this txt are different from the OmniClass list provided by Revit?
And I found that when opening different family files, the OmniClass list provided by Revit will be different.
Solved by b10705001F2HWP. Go to Solution.
Modify the OmniClass parameter value in the family file.
I think I have found the problem, because I didn't update the taxonomy file associated with revit...
Thank you for your reply! 😃
