Extra lines appear when importing cadd drawing into revit
12 REPLIES 12
Message 1 of 13
chhuanmawia18
1462 Views, 12 Replies
these lines (highlighted and pointed in arrow)appear when importing cadd 3d contour lines and creating a toposurface. they are not a layer in the cadd drawing but appear when creating the toposurface from imported file option . how can i turn them off or delete themlines.JPG
12 REPLIES 12
Message 2 of 13
kadmonkee
in reply to: chhuanmawia18
link the file and only turn on layers you need in Revit , create your topo surface then turn off the link to see if that is cleaner
if the cad file is imported then only import the layers you need
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 13
hmunsell
there may be a Surface already in the C3D file. like @kadmonkee  suggests, check your layers that are coming in from the CAD file.
  • VG > Imported Categories
  • select the CAD Link
  • uncheck the unwanted layers.
    • you may need to talk to the C3D person and find out what layers they  are using.
Howard Munsell
Message 4 of 13
That's not uncommon.  You may be able to "smooth" them out through using the Simplify Surface tool (available inside Toposurface edit mode).
...another way, is by adding ZERO Elevation Points RELATIVE TO SURFACE in the vicinity of that line work.
Message 5 of 13
chhuanmawia18
in reply to: kadmonkee
i did this but still not working
Message 6 of 13
chhuanmawia18
in reply to: hmunsell
the lines are not a part of autocadd layers in this problem
Message 7 of 13
tried it butnot working
Message 8 of 13
Post the 2 files.
Message 9 of 13
hmunsell
can you post the file?
Howard Munsell
Message 10 of 13
here it is
Message 11 of 13
chhuanmawia18
posted it , the acadd file is from a surveyor
Message 12 of 13
comes out beautiful if I just select the Layers CONT-MJR and CONT_MNR.
Message 13 of 13
thanksa lot! still having some problems but this was really useful
