Extra lines appear when importing cadd drawing into revit
chhuanmawia18
chhuanmawia18
these lines (highlighted and pointed in arrow)appear when importing cadd 3d contour lines and creating a toposurface. they are not a layer in the cadd drawing but appear when creating the toposurface from imported file option . how can i turn them off or delete themlines.JPG
Replies (12)
kadmonkee
link the file and only turn on layers you need in Revit , create your topo surface then turn off the link to see if that is cleaner
if the cad file is imported then only import the layers you need
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
hmunsell
there may be a Surface already in the C3D file. like @kadmonkee  suggests, check your layers that are coming in from the CAD file.
  • VG > Imported Categories
  • select the CAD Link
  • uncheck the unwanted layers.
    • you may need to talk to the C3D person and find out what layers they  are using.
Howard Munsell
That's not uncommon.  You may be able to "smooth" them out through using the Simplify Surface tool (available inside Toposurface edit mode).
...another way, is by adding ZERO Elevation Points RELATIVE TO SURFACE in the vicinity of that line work.
chhuanmawia18
i did this but still not working
chhuanmawia18
the lines are not a part of autocadd layers in this problem
chhuanmawia18
tried it butnot working
Post the 2 files.
hmunsell
can you post the file?
Howard Munsell
chhuanmawia18
here it is
chhuanmawia18
posted it , the acadd file is from a surveyor
comes out beautiful if I just select the Layers CONT-MJR and CONT_MNR.
chhuanmawia18
thanksa lot! still having some problems but this was really useful
