Extents of Structural Beam Systems
4 REPLIES 4
steve
349 Views, 4 Replies
can anyone point out what controls the way the extents of beams within a structural beam system?    See video...
https://drive.google.com/file/d/1jdeaElZnQUybct6AFl1ZLUeV24MUyUiB/view?usp=drivesdk
4 REPLIES 4
RobDraw
in reply to: steve
Why don't you just respond, say you found the answer, mark it as the solution like you usually do and get it over with?
Rob
steve
in reply to: steve
 I just posted this, I didn't find an answer.
in reply to: steve
 Looks to me like the Beams are interacting with a Structural Support. Is that a Structural Wall they are butting up against? Select the Wall an uncheck "Structural" and see if the Beams' extents change.
steve
in reply to: barthbradley
Yes, that was it.    Although that wall (now unchecked) is below the joist and the framing system bears on that wall, therefore is structural - and we'd want it shown in framing plans.  making it non-structural takes it out of the framing plan.  I'll work with visibilities.   also can make its level an underaly
Forma Design Contest
Technology Administrators
