can anyone point out what controls the way the extents of beams within a structural beam system? See video...
https://drive.google.com/file/d/1jdeaElZnQUybct6AFl1ZLUeV24MUyUiB/view?usp=drivesdk
Solved by barthbradley. Go to Solution.
Solved by RobDraw. Go to Solution.
Why don't you just respond, say you found the answer, mark it as the solution like you usually do and get it over with?
Looks to me like the Beams are interacting with a Structural Support. Is that a Structural Wall they are butting up against? Select the Wall an uncheck "Structural" and see if the Beams' extents change.
Yes, that was it. Although that wall (now unchecked) is below the joist and the framing system bears on that wall, therefore is structural - and we'd want it shown in framing plans. making it non-structural takes it out of the framing plan. I'll work with visibilities. also can make its level an underaly
