Error when using DB LInk Add0In in revit 2019
Message 1 of 9
Hello
When I am using DB Link Add-In in Revit 2019 for export model information, i encounter this error. please help me.
Replies (8)
Message 2 of 9
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community! Thanks for posting on our forum.
  • Are you on windows 10?
  • Check if the disk on which the SQL Server is trying to create the database has enough free space.
  • This error message is issued by the SQL Server when it can't create database files.
  • Upgrade MS SQL server and please follow the instructions in the Vault help Upgrade MS SQL Server and MS SQL Express.
Looking forward to hearing back from you.
Message 3 of 9
yes i'm on windows 10 but i want to export model information to access not sql server.
Message 4 of 9
Viveka_CD
Hi @Anonymous
Thanks for clarifying.Smiley Happy
Let me do some research on this issue and get back to you.
Meanwhile, please confirm if you have the latest build of Revit.
Message 5 of 9
Viveka_CD
Hi @Anonymous
Can you share the Revit file and the latest journal file to investigate further?
I can send you a private folder to upload.
Meanwhile, can you check the memory, it's possible that you get an error of this kind if you are low on server memory.
Message 6 of 9
Viveka_CD
Hi @Anonymous
I wanted to follow up on your issue.
I'll be glad to investigate further if you can send the files over.
Let me know and I look forward to hearing from you.
Message 7 of 9
icasares
Observer
Observer
I have Revit 2018 and Windows 10 and I have the exact same problem. Db link always shows this message. I have more than enough place in my hard drive, I also tried to export to another hard drive, to a flsh disc, no matter where it always displays this message.
I would apreciate any solution to this issue.
Thank you.
Message 8 of 9
ArthurADas
Were you able to solve the problem, icasares?
I'm getting the same error.
One solution that i found that solved this problem for a fews days was:
Download and install Microsoft Access Database Engine 2010 Redistributable.
I found the installer file on Microsoft's website
https://www.microsoft.com/en-us/download/details.aspx?id=13255
Unfortunetally this solution worked for a few days only and now i'm searching for more solutions.
Arthur
Message 9 of 9
icasares
Observer
Observer
Hello Arthur,
I could solve the problem installing an AccesDatabaseEngine_x64_v2010. With this database DB-Link is still working.
I hope it helps...
