Allow me to introduce to to my Stair -
I would like to remove the highlighted area between the railings. I did try to incorporate the cut out in my sketch, but Revit did not like it. Ideas?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hi @Sahay_R
How are you doing? Glad to hear.
Which version of Revit are you using? Can you share the file?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @Viveka_CD! It's Revit 2018.3. Here's the stair - very straightforward, until I try to change the sketch like this -
Ouch @ToanDN. That's just what I didn't want to do. Create three runs and jerry-rig them together? Possible to cut out with a void? (2nd worst case scenario).
BTW congrats on the 12 - it looks good on you....Hi @Sahay_R
A couple of runs should do the trick, but I see that you want a cut-out?
Viveka CD
THAT way! Thank you!
Revit Grandmaster @ToanDN ![]()
Viveka CD
How can i model this of stair in revit anyone please tell me the step.
- Start an assemble stair
- Draw run 1 (narrow) from bottom to landing
- Draw run 2 (wide) from landing to top
- Let Revit create the landing connecting run 1 and run 2 automatically
- Copy run 1 to create run 1b
- Convert landing to sketch and modify the shape as needed
