Error when installing Revit 2015 on Windows 10 Home Dell Inspiron 15 8GB
I am having issues when installing Revit. Once the program has installed it comes up with errors where the product failed to install.
Please see the attachment below:
The failing entries in the log file shown below:
Log file fail for Revit2015:
2016/8/29:10:19:05 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2016/8/29:10:19:05 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/8/29:10:19:05 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2016/8/29:10:19:05 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2016/8/29:10:19:05 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2016/8/29:10:19:05 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Log file fail for Material Libraries:
Log file fail for Content Libraries:
If anyone has any suggestions on how to complete the installation I would really appreciate it.
Many thanks
Emma
nathan.chapman
Emma-
This link should get you squared away.  http://forums.autodesk.com/t5/installation-licensing/failed-to-install-error-1619/td-p/3653340.  One of your prerequiste is probably the issue.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
TravisNave
The error is above the rollbacks.  Post the entire log.
Chances are it is the BIM 360 failing to install.  Uncheck it and try again.  If it fails again, post the full log.
Good Luck!
Autodesk Forums:
Thank you for your message. Please see the full logs below:
2016/8/29:09:21:42 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/8/29:09:21:42 Emma DESKTOP-JITN5MM Path_Length: 155
2016/8/29:09:21:42 Emma DESKTOP-JITN5MM Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US
2016/8/29:09:21:42 Emma DESKTOP-JITN5MM Launch
2016/8/29:09:21:42 Emma DESKTOP-JITN5MM CommandLine /PK 829G1 /SN 900-68127510 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US..."
2016/8/29:09:21:42 Emma DESKTOP-JITN5MM Setup Windows update reboot is pending
2016/8/29:09:21:49 Emma DESKTOP-JITN5MM Setup Autodesk Revit 2015 Will restart automatically.
2016/8/29:09:21:49 Emma DESKTOP-JITN5MM === Setup ended ===
2016/8/29:09:41:03 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/8/29:09:41:03 Emma DESKTOP-JITN5MM Path_Length: 155
2016/8/29:09:41:03 Emma DESKTOP-JITN5MM Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US
2016/8/29:09:41:03 Emma DESKTOP-JITN5MM Launch
2016/8/29:09:41:03 Emma DESKTOP-JITN5MM CommandLine /PK 829G1 /SN 900-68127510 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US..."
2016/8/29:09:41:03 Emma DESKTOP-JITN5MM Current Directory C:\Users\Emma\AppData\Local\Temp\_AI2ABF.tmp
2016/8/29:09:41:51 Emma DESKTOP-JITN5MM === Setup ended ===
2016/8/29:09:41:04 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/8/29:09:41:04 Emma DESKTOP-JITN5MM Path_Length: 155
2016/8/29:09:41:04 Emma DESKTOP-JITN5MM Current Directory C:\Users\Emma\AppData\Local\Temp\_AI2ABF.tmp
2016/8/29:09:41:04 Emma DESKTOP-JITN5MM Launch
2016/8/29:09:41:33 Emma DESKTOP-JITN5MM Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64....
2016/8/29:09:41:51 Emma DESKTOP-JITN5MM Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64....
2016/8/29:09:41:51 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AI2ABF.tmp\Setup\RevitSetup.dll
2016/8/29:09:41:51 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/8/29:09:41:51 Emma DESKTOP-JITN5MM PageOpen LaunchDialog
2016/8/29:09:42:04 Emma DESKTOP-JITN5MM PageOpen LicenseDialog
2016/8/29:09:42:04 Emma DESKTOP-JITN5MM PageOpen ProductSelectionDialog2
2016/8/29:09:43:10 Emma DESKTOP-JITN5MM PageOpen LicenseDialog
2016/8/29:09:43:10 Emma DESKTOP-JITN5MM PageOpen LaunchDialog
2016/8/29:09:43:13 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AI2ABF.tmp\Setup\RevitSetup.dll
2016/8/29:09:43:13 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2016/8/29:09:44:38 Emma DESKTOP-JITN5MM PageOpen LicenseDialog
2016/8/29:09:44:38 Emma DESKTOP-JITN5MM PageOpen ProductInfoDialog
2016/8/29:09:44:38 Emma DESKTOP-JITN5MM PageOpen ProductSelectionDialog2
2016/8/29:09:46:55 Emma DESKTOP-JITN5MM PageOpen FullProgressDialog
2016/8/29:09:46:56 Emma DESKTOP-JITN5MM Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:46:58 Emma DESKTOP-JITN5MM Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:46:58 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2016/8/29:09:47:29 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2016/8/29:09:47:29 Emma DESKTOP-JITN5MM Download Play VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:47:31 Emma DESKTOP-JITN5MM Download Complete VCREDIST2008SP1X64_6161 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:47:31 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2016/8/29:09:47:50 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2016/8/29:09:47:50 Emma DESKTOP-JITN5MM Download Play VCREDIST2005X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:47:53 Emma DESKTOP-JITN5MM Download Complete VCREDIST2005X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:47:53 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Emma\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/8/29:09:48:10 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2016/8/29:09:48:10 Emma DESKTOP-JITN5MM Download Play VCREDIST2005X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:48:12 Emma DESKTOP-JITN5MM Download Complete VCREDIST2005X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:48:12 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Emma\AppData\Local\Temp\vcredist_x64_2005.log"" "
2016/8/29:09:48:31 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2016/8/29:09:48:32 Emma DESKTOP-JITN5MM Download Play VCREDIST2008SP1X86_6161 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:48:37 Emma DESKTOP-JITN5MM Download Complete VCREDIST2008SP1X86_6161 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:48:37 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2016/8/29:09:48:58 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2016/8/29:09:48:59 Emma DESKTOP-JITN5MM Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:49:01 Emma DESKTOP-JITN5MM Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:49:01 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2016/8/29:09:49:09 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2016/8/29:09:49:10 Emma DESKTOP-JITN5MM Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:49:12 Emma DESKTOP-JITN5MM Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:49:12 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2016/8/29:09:49:20 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2016/8/29:09:49:21 Emma DESKTOP-JITN5MM Download Play VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:49:23 Emma DESKTOP-JITN5MM Download Complete VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:49:23 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/8/29:09:49:44 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/8/29:09:49:45 Emma DESKTOP-JITN5MM Download Play VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:49:47 Emma DESKTOP-JITN5MM Download Complete VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:49:47 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/8/29:09:51:12 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/8/29:09:51:12 Emma DESKTOP-JITN5MM Download Play KB958314ATLX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314AT...
2016/8/29:09:51:13 Emma DESKTOP-JITN5MM Download Complete KB958314ATLX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314AT...
2016/8/29:09:51:13 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:09:51:19 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2016/8/29:09:51:19 Emma DESKTOP-JITN5MM Download Play KB958314MFCX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314MF...
2016/8/29:09:51:22 Emma DESKTOP-JITN5MM Download Complete KB958314MFCX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314MF...
2016/8/29:09:51:22 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:09:51:41 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2016/8/29:09:51:41 Emma DESKTOP-JITN5MM Download Play KB958314CRTX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314CR...
2016/8/29:09:51:42 Emma DESKTOP-JITN5MM Download Complete KB958314CRTX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314CR...
2016/8/29:09:51:42 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:09:51:54 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2016/8/29:09:51:54 Emma DESKTOP-JITN5MM Download Play KB958314OPENMPX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314OP...
2016/8/29:09:51:55 Emma DESKTOP-JITN5MM Download Complete KB958314OPENMPX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314OP...
2016/8/29:09:51:55 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:09:52:06 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2016/8/29:09:52:06 Emma DESKTOP-JITN5MM Download Play KB958314ATLX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314AT...
2016/8/29:09:52:07 Emma DESKTOP-JITN5MM Download Complete KB958314ATLX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314AT...
2016/8/29:09:52:07 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:09:52:12 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2016/8/29:09:52:12 Emma DESKTOP-JITN5MM Download Play KB958314MFCX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314MF...
2016/8/29:09:52:15 Emma DESKTOP-JITN5MM Download Complete KB958314MFCX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314MF...
2016/8/29:09:52:15 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:09:52:27 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2016/8/29:09:52:27 Emma DESKTOP-JITN5MM Download Play KB958314CRTX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314CR...
2016/8/29:09:52:28 Emma DESKTOP-JITN5MM Download Complete KB958314CRTX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314CR...
2016/8/29:09:52:28 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:09:52:37 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2016/8/29:09:52:38 Emma DESKTOP-JITN5MM Download Play KB958314OPENMPX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314OP...
2016/8/29:09:52:38 Emma DESKTOP-JITN5MM Download Complete KB958314OPENMPX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/KB958314OP...
2016/8/29:09:52:38 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:09:52:47 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2016/8/29:09:52:47 Emma DESKTOP-JITN5MM Download Play VCREDIST2005SP1ATLX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:52:48 Emma DESKTOP-JITN5MM Download Complete VCREDIST2005SP1ATLX86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:52:49 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Emma\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/8/29:09:53:19 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2016/8/29:09:53:19 Emma DESKTOP-JITN5MM Download Play VCREDIST2005SP1ATLX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:53:21 Emma DESKTOP-JITN5MM Download Complete VCREDIST2005SP1ATLX64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/8/29:09:53:21 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Emma\AppData\Local\Temp\vcredist_x64_2005.log"" "
2016/8/29:09:53:46 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2016/8/29:09:53:46 Emma DESKTOP-JITN5MM Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:09:54:00 Emma DESKTOP-JITN5MM Install FaroSDK Succeeded
2016/8/29:09:54:01 Emma DESKTOP-JITN5MM Download Play RCL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RCL2015_x6...
2016/8/29:09:54:07 Emma DESKTOP-JITN5MM Download Complete RCL2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RCL2015_x6...
2016/8/29:09:54:07 Emma DESKTOP-JITN5MM Installing Autodesk® Revit® Content Libraries 2015: TRANSFORMS="C:\Users\Emma\AppData\Local\Temp\_AI2ABF.tmp\x64\RCL2015\RCL2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:10:03:41 Emma DESKTOP-JITN5MM Install Autodesk® Revit® Content Libraries 2015 Succeeded
2016/8/29:10:03:42 Emma DESKTOP-JITN5MM Download Play RVT2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x6...
2016/8/29:10:08:00 Emma DESKTOP-JITN5MM Download Complete RVT2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x6...
2016/8/29:10:08:08 Emma DESKTOP-JITN5MM Installing Autodesk® Revit® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2015\x64\en-us\RVT2015\RVT2015.mst;C:\Users\Emma\AppData\Local\Temp\_AI2ABF.tmp\x64\RVT2015\RVT2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:10:14:10 Emma DESKTOP-JITN5MM Install Autodesk® Revit® 2015 Succeeded
2016/8/29:10:14:10 Emma DESKTOP-JITN5MM Download Play RVT2015_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x6...
2016/8/29:10:14:17 Emma DESKTOP-JITN5MM Download Complete RVT2015_en-us http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x6...
2016/8/29:10:14:18 Emma DESKTOP-JITN5MM Installing Autodesk® Revit® 2015 Language Pack: TRANSFORMS="C:\Users\Emma\AppData\Local\Temp\_AI2ABF.tmp\_la96D0.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:10:14:24 Emma DESKTOP-JITN5MM Install Autodesk® Revit® 2015 Language Pack Succeeded
2016/8/29:10:14:25 Emma DESKTOP-JITN5MM Installing Autodesk Workflows 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:10:14:29 Emma DESKTOP-JITN5MM Install Autodesk Workflows 2015 Succeeded
2016/8/29:10:14:29 Emma DESKTOP-JITN5MM Download Play CM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CM2015.tar...
2016/8/29:10:14:42 Emma DESKTOP-JITN5MM Download Complete CM2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CM2015.tar...
2016/8/29:10:14:43 Emma DESKTOP-JITN5MM Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/8/29:10:14:58 Emma DESKTOP-JITN5MM Install Autodesk Material Library 2015 Succeeded
2016/8/29:10:14:58 Emma DESKTOP-JITN5MM Download Play CMILB2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILB2015....
2016/8/29:10:15:15 Emma DESKTOP-JITN5MM Download Aborted CMILB2015 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILB2015....
2016/8/29:10:15:15 Emma DESKTOP-JITN5MM Install Autodesk Material Library 2015 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/8/29:10:15:41 Emma DESKTOP-JITN5MM Rollback Autodesk Material Library 2015 Succeeded
2016/8/29:10:15:42 Emma DESKTOP-JITN5MM Rollback Autodesk Workflows 2015 Succeeded
2016/8/29:10:15:45 Emma DESKTOP-JITN5MM Rollback Autodesk® Revit® 2015 Language Pack Succeeded
2016/8/29:10:16:36 Emma DESKTOP-JITN5MM Rollback Autodesk® Revit® 2015 Succeeded
2016/8/29:10:17:59 Emma DESKTOP-JITN5MM Rollback Autodesk® Revit® Content Libraries 2015 Succeeded
2016/8/29:10:18:29 Emma DESKTOP-JITN5MM Rollback FaroSDK Succeeded
2016/8/29:10:18:29 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619
2016/8/29:10:18:29 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2016/8/29:10:18:34 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2016/8/29:10:18:38 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2016/8/29:10:18:42 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2016/8/29:10:18:44 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2016/8/29:10:18:49 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2016/8/29:10:18:54 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2016/8/29:10:19:02 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2016/8/29:10:19:04 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
Many thanks for your help
Emma
Unchecked all (autodesk revit content libraries 2015 and autodesk BIM 360 Add in For Revit 2015. I kept the top one "Autodesk Revit 2015" checked.
2016/8/29:10:19:09 Emma DESKTOP-JITN5MM PageOpen InstallCompleteDialog
2016/9/4:11:23:12 Emma DESKTOP-JITN5MM === Setup ended ===
2016/9/4:11:24:32 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/9/4:11:24:32 Emma DESKTOP-JITN5MM Path_Length: 155
2016/9/4:11:24:32 Emma DESKTOP-JITN5MM Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US
2016/9/4:11:24:32 Emma DESKTOP-JITN5MM Launch
2016/9/4:11:24:32 Emma DESKTOP-JITN5MM CommandLine /PK 829G1 /SN 900-68127510 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US..."
2016/9/4:11:24:32 Emma DESKTOP-JITN5MM Current Directory C:\Users\Emma\AppData\Local\Temp\_AIE07.tmp
2016/9/4:11:24:35 Emma DESKTOP-JITN5MM === Setup ended ===
2016/9/4:11:24:33 Emma DESKTOP-JITN5MM Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64....
2016/9/4:11:24:34 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AIE07.tmp\Setup\RevitSetup.dll
2016/9/4:11:24:34 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/4:11:24:35 Emma DESKTOP-JITN5MM PageOpen LaunchDialog
2016/9/4:11:24:45 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AIE07.tmp\Setup\RevitSetup.dll
2016/9/4:11:24:45 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2016/9/4:11:25:12 Emma DESKTOP-JITN5MM PageOpen LicenseDialog
2016/9/4:11:25:12 Emma DESKTOP-JITN5MM PageOpen ProductInfoDialog
2016/9/4:11:25:12 Emma DESKTOP-JITN5MM PageOpen ProductSelectionDialog2
2016/9/4:11:28:39 Emma DESKTOP-JITN5MM PageOpen FullProgressDialog
2016/9/4:11:28:39 Emma DESKTOP-JITN5MM Download Skipped VCREDIST2005X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/9/4:11:28:39 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Emma\AppData\Local\Temp\vcredist_x86_2005.log"" "
2016/9/4:11:29:02 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2016/9/4:11:29:02 Emma DESKTOP-JITN5MM Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/9/4:11:29:02 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/9/4:11:29:28 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/4:11:29:28 Emma DESKTOP-JITN5MM Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/9/4:11:29:28 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/9/4:11:29:29 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=-2147024546
2016/9/4:11:29:29 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/4:11:29:29 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/4:11:29:30 Emma DESKTOP-JITN5MM PageOpen InstallCompleteDialog
2016/9/4:11:31:27 Emma DESKTOP-JITN5MM === Setup ended ===
2016/9/4:11:32:01 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/9/4:11:32:01 Emma DESKTOP-JITN5MM Path_Length: 155
2016/9/4:11:32:01 Emma DESKTOP-JITN5MM Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US
2016/9/4:11:32:01 Emma DESKTOP-JITN5MM Launch
2016/9/4:11:32:01 Emma DESKTOP-JITN5MM CommandLine /PK 829G1 /SN 900-68127510 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US..."
2016/9/4:11:32:01 Emma DESKTOP-JITN5MM Current Directory C:\Users\Emma\AppData\Local\Temp\_AIE791.tmp
2016/9/4:11:32:03 Emma DESKTOP-JITN5MM === Setup ended ===
2016/9/4:11:32:02 Emma DESKTOP-JITN5MM Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64....
2016/9/4:11:32:02 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AIE791.tmp\Setup\RevitSetup.dll
2016/9/4:11:32:02 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/4:11:32:03 Emma DESKTOP-JITN5MM PageOpen LaunchDialog
2016/9/4:11:32:08 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AIE791.tmp\Setup\RevitSetup.dll
2016/9/4:11:32:08 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2016/9/4:11:32:29 Emma DESKTOP-JITN5MM PageOpen LicenseDialog
2016/9/4:11:32:29 Emma DESKTOP-JITN5MM PageOpen ProductInfoDialog
2016/9/4:11:32:29 Emma DESKTOP-JITN5MM PageOpen ProductSelectionDialog2
2016/9/4:11:32:53 Emma DESKTOP-JITN5MM PageOpen FullProgressDialog
2016/9/4:11:32:54 Emma DESKTOP-JITN5MM Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/9/4:11:32:54 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/9/4:11:32:55 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/4:11:32:55 Emma DESKTOP-JITN5MM Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/9/4:11:32:55 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/9/4:11:32:55 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=-2147024546
2016/9/4:11:32:55 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/4:11:32:55 Emma DESKTOP-JITN5MM PageOpen InstallCompleteDialog
2016/9/4:11:33:30 Emma DESKTOP-JITN5MM === Setup ended ===
2016/9/4:11:34:04 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/9/4:11:34:04 Emma DESKTOP-JITN5MM Path_Length: 155
2016/9/4:11:34:04 Emma DESKTOP-JITN5MM Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US
2016/9/4:11:34:04 Emma DESKTOP-JITN5MM Launch
2016/9/4:11:34:04 Emma DESKTOP-JITN5MM CommandLine /PK 829G1 /SN 900-68127510 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US..."
2016/9/4:11:34:04 Emma DESKTOP-JITN5MM Current Directory C:\Users\Emma\AppData\Local\Temp\_AIC922.tmp
2016/9/4:11:34:06 Emma DESKTOP-JITN5MM === Setup ended ===
2016/9/4:11:34:05 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/9/4:11:34:05 Emma DESKTOP-JITN5MM Path_Length: 155
2016/9/4:11:34:05 Emma DESKTOP-JITN5MM Current Directory C:\Users\Emma\AppData\Local\Temp\_AIC922.tmp
2016/9/4:11:34:05 Emma DESKTOP-JITN5MM Launch
2016/9/4:11:34:05 Emma DESKTOP-JITN5MM Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64....
2016/9/4:11:34:05 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AIC922.tmp\Setup\RevitSetup.dll
2016/9/4:11:34:05 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/4:11:34:06 Emma DESKTOP-JITN5MM PageOpen LaunchDialog
2016/9/4:11:34:11 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AIC922.tmp\Setup\RevitSetup.dll
2016/9/4:11:34:11 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2016/9/4:11:34:29 Emma DESKTOP-JITN5MM PageOpen LicenseDialog
2016/9/4:11:34:29 Emma DESKTOP-JITN5MM PageOpen ProductInfoDialog
2016/9/4:11:34:29 Emma DESKTOP-JITN5MM PageOpen ProductSelectionDialog2
2016/9/4:11:35:00 Emma DESKTOP-JITN5MM PageOpen FullProgressDialog
2016/9/4:11:35:00 Emma DESKTOP-JITN5MM Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/9/4:11:35:00 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/9/4:11:35:01 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/4:11:35:01 Emma DESKTOP-JITN5MM Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/9/4:11:35:01 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/9/4:11:35:02 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=-2147024546
2016/9/4:11:35:02 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/4:11:35:02 Emma DESKTOP-JITN5MM PageOpen InstallCompleteDialog
2016/9/4:11:35:36 Emma DESKTOP-JITN5MM === Setup ended ===
2016/9/4:11:36:46 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/9/4:11:36:46 Emma DESKTOP-JITN5MM Path_Length: 155
2016/9/4:11:36:46 Emma DESKTOP-JITN5MM Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US
2016/9/4:11:36:46 Emma DESKTOP-JITN5MM Launch
2016/9/4:11:36:46 Emma DESKTOP-JITN5MM CommandLine /PK 829G1 /SN 900-68127510 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US..."
2016/9/4:11:36:46 Emma DESKTOP-JITN5MM Current Directory C:\Users\Emma\AppData\Local\Temp\_AI4175.tmp
2016/9/4:11:36:48 Emma DESKTOP-JITN5MM === Setup ended ===
2016/9/4:11:36:47 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/9/4:11:36:47 Emma DESKTOP-JITN5MM Path_Length: 155
2016/9/4:11:36:47 Emma DESKTOP-JITN5MM Current Directory C:\Users\Emma\AppData\Local\Temp\_AI4175.tmp
2016/9/4:11:36:47 Emma DESKTOP-JITN5MM Launch
2016/9/4:11:36:47 Emma DESKTOP-JITN5MM Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64....
2016/9/4:11:36:47 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AI4175.tmp\Setup\RevitSetup.dll
2016/9/4:11:36:48 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/4:11:36:48 Emma DESKTOP-JITN5MM PageOpen LaunchDialog
2016/9/4:11:36:53 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AI4175.tmp\Setup\RevitSetup.dll
2016/9/4:11:36:53 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2016/9/4:11:37:11 Emma DESKTOP-JITN5MM PageOpen LicenseDialog
2016/9/4:11:37:11 Emma DESKTOP-JITN5MM PageOpen ProductInfoDialog
2016/9/4:11:37:11 Emma DESKTOP-JITN5MM PageOpen ProductSelectionDialog2
2016/9/4:11:38:09 Emma DESKTOP-JITN5MM PageOpen FullProgressDialog
2016/9/4:11:38:09 Emma DESKTOP-JITN5MM Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/9/4:11:38:09 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/9/4:11:38:10 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/4:11:38:10 Emma DESKTOP-JITN5MM Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/9/4:11:38:10 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/9/4:11:38:11 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=-2147024546
2016/9/4:11:38:11 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2016/9/4:11:38:11 Emma DESKTOP-JITN5MM PageOpen InstallCompleteDialog
2016/9/4:11:39:07 Emma DESKTOP-JITN5MM === Setup ended ===
2016/9/6:14:32:09 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/9/6:14:32:09 Emma DESKTOP-JITN5MM Path_Length: 155
2016/9/6:14:32:09 Emma DESKTOP-JITN5MM Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US
2016/9/6:14:32:09 Emma DESKTOP-JITN5MM Launch
2016/9/6:14:32:09 Emma DESKTOP-JITN5MM CommandLine /PK 829G1 /SN 900-68127510 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US..."
2016/9/6:14:32:09 Emma DESKTOP-JITN5MM Current Directory C:\Users\Emma\AppData\Local\Temp\_AI8D8D.tmp
2016/9/6:14:32:12 Emma DESKTOP-JITN5MM === Setup ended ===
2016/9/6:14:32:10 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/9/6:14:32:10 Emma DESKTOP-JITN5MM Path_Length: 155
2016/9/6:14:32:10 Emma DESKTOP-JITN5MM Current Directory C:\Users\Emma\AppData\Local\Temp\_AI8D8D.tmp
2016/9/6:14:32:10 Emma DESKTOP-JITN5MM Launch
2016/9/6:14:32:11 Emma DESKTOP-JITN5MM Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64....
2016/9/6:14:32:12 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AI8D8D.tmp\Setup\RevitSetup.dll
2016/9/6:14:32:12 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/6:14:32:12 Emma DESKTOP-JITN5MM PageOpen LaunchDialog
2016/9/6:14:32:22 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AI8D8D.tmp\Setup\RevitSetup.dll
2016/9/6:14:32:22 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2016/9/6:14:32:48 Emma DESKTOP-JITN5MM PageOpen LicenseDialog
2016/9/6:14:32:48 Emma DESKTOP-JITN5MM PageOpen ProductInfoDialog
2016/9/6:14:32:49 Emma DESKTOP-JITN5MM PageOpen ProductSelectionDialog2
2016/9/6:14:39:20 Emma DESKTOP-JITN5MM === Setup ended ===
2016/9/6:14:53:20 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/9/6:14:53:20 Emma DESKTOP-JITN5MM Path_Length: 155
2016/9/6:14:53:20 Emma DESKTOP-JITN5MM Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US
2016/9/6:14:53:20 Emma DESKTOP-JITN5MM Launch
2016/9/6:14:53:20 Emma DESKTOP-JITN5MM CommandLine /PK 829G1 /SN 900-68127510 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US..."
2016/9/6:14:53:20 Emma DESKTOP-JITN5MM Current Directory C:\Users\Emma\AppData\Local\Temp\_AIF1E8.tmp
2016/9/6:14:53:23 Emma DESKTOP-JITN5MM === Setup ended ===
2016/9/6:14:53:21 Emma DESKTOP-JITN5MM === Setup started on DESKTOP-JITN5MM by Emma ===
2016/9/6:14:53:21 Emma DESKTOP-JITN5MM Path_Length: 155
2016/9/6:14:53:21 Emma DESKTOP-JITN5MM Current Directory C:\Users\Emma\AppData\Local\Temp\_AIF1E8.tmp
2016/9/6:14:53:21 Emma DESKTOP-JITN5MM Launch
2016/9/6:14:53:22 Emma DESKTOP-JITN5MM Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64....
2016/9/6:14:53:22 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AIF1E8.tmp\Setup\RevitSetup.dll
2016/9/6:14:53:22 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/6:14:53:23 Emma DESKTOP-JITN5MM PageOpen LaunchDialog
2016/9/6:14:53:29 Emma DESKTOP-JITN5MM Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Emma\AppData\Local\Temp\_AIF1E8.tmp\Setup\RevitSetup.dll
2016/9/6:14:53:29 Emma DESKTOP-JITN5MM Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2016/9/6:14:53:47 Emma DESKTOP-JITN5MM PageOpen LicenseDialog
2016/9/6:14:53:47 Emma DESKTOP-JITN5MM PageOpen ProductInfoDialog
2016/9/6:14:53:47 Emma DESKTOP-JITN5MM PageOpen ProductSelectionDialog2
2016/9/6:14:59:29 Emma DESKTOP-JITN5MM PageOpen FullProgressDialog
2016/9/6:14:59:29 Emma DESKTOP-JITN5MM Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/9/6:14:59:29 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/9/6:14:59:44 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/6:14:59:44 Emma DESKTOP-JITN5MM Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST20...
2016/9/6:14:59:44 Emma DESKTOP-JITN5MM Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/9/6:14:59:45 Emma DESKTOP-JITN5MM Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=-2147024546
2016/9/6:14:59:45 Emma DESKTOP-JITN5MM Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
