Elevation in Detail Callout
23 REPLIES 23
Message 1 of 24
elky853
6229 Views, 23 Replies
I wanna create elevation references from a callout (see image). Is that possible at all?
Thanks!
23 REPLIES 23
Message 2 of 24
cbcarch
in reply to: elky853
View Tab>Elevation.
In you Plan View, make sure Elevations are turned on in Visibility Graphics (VG) in Annotation Categories.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 24
elky853
in reply to: cbcarch
It is turned on.
But what I'm asking is if it's at all possible to make it visible in a callout, because 'Elevation' is grayed out. (see attached image).
Message 4 of 24
That looks like the stock "Interior Elevation". So after pressing Elevation on the View Tab, select the Elevation Type from the Properties Palette Type Selector.
Message 5 of 24
Go to a Plan View.
Message 6 of 24
elky853
in reply to: barthbradley
I created an interior elevation, as @barthbradley advised, in Plan View, but I can't make it visible in a callout. (It's turned on in VG).
Also how do I create the North/South/East/West Elev? The one I created is as follow:
Message 7 of 24
cbcarch
Check the boxes at the other 3 elevation markers (triangles). This will create the elevations.
In the Callout View, under VG, check if any Filters are applied that would have the Elevation Type turned off.
Cliff B. Collins
Message 8 of 24
I'm not understanding the question. Elevation Markers are placed in Plan Views for the purpose of creating a 2D Elevation View.
Also, do you mean you want the Marker to display the Name of the View, such as "North", "South", "East", "West"?  If so, name the Elevation View "North", "South", "East", or "West".
Message 9 of 24
elky853
No filters are applied... Can there be any other reason why the elevation marks aren't showing up?
Message 10 of 24
cbcarch
Try creating a new Elevation inside the Callout/Plan View. Do all 4 sides show up?
Cliff B. Collins
Message 11 of 24
elky853
I created the elevation in Plan View and I have all 4 sides showing up. The issue is only that the actual Elevation Tag isn't showing up in Callout view.
Message 12 of 24
elky853
also the elevation tag itself (which is visible in plan view) is wayyyy too big. Any idea how to scale it down?
Message 13 of 24
cbcarch
The Elevation Mark is the correct size.
Try increasing the scale of your Plan View/Callout instead.
i.e. your Floor Plan/Callout is too small, making the Elevation Mark look too big.
Cliff B. Collins
Message 14 of 24
Callouts AND every Annotation, are VIEW-SPECIFIC.  The Callout View is a new View.  It won't show the View-Specific Annotations in the source View.
Annotation Elements | Revit Products | Autodesk Knowledge Network
Message 15 of 24
elky853
So how do I change it so it shouldn't be view-specific but should show up wherever the category 'elevations' is turned on?
Message 16 of 24
Clipboard Copy and Paste Aligned to same Place.
Message 17 of 24
Actually, I'm wrong. First time that's ever happened. Weird experience. 😉
Message 18 of 24
elky853
Can't Copy paste.
Message 19 of 24
elky853
Lol k what was that wrong thing you said? I'm all confused now
Message 20 of 24
TripleM-Dev.net
Seems if you make a Callout from the "Callout - Detail"-family of a Floorplan; elevation symbols won't show, also you can't place new elevations in this callout.
"Callout - Detail" family views also can't be duplicated as dependent, guess it's has different functionality than other view types.
You can create a Callout using the "Callout - Floorplan" family, this will function identical to the Floorplan itself, elevation markers show etc...
- Michel
Forma Design Contest
Technology Administrators
