elevation ground line
8 REPLIES 8
Message 1 of 9
11346 Views, 8 Replies
I have an elevation and I want to show the ground line with a Ground line only and I dont need to show the earth hatch pattern like the image below. How can I do that? The one I currently have is the second image. I have tried to go VG and untick the site . I have also tried changing the cut pattern in the propoerty of the site but it did NOT work untill this point. As much as a begginer issues this may seem but there is no utorial which has covered this from my understadning.
8 REPLIES 8
Message 2 of 9
ennujozlagam
Hello, have you tried pick earth right click in your mouse and choose hide elements in view. Thanks
Message 3 of 9
in reply to: ennujozlagam
YES BUT IT hides the ground line as well which I realy need. HOwever I also did try TAB to see if I just can select the hatch pattern but iut did NOT work.
Message 4 of 9
constantin.stroescu
In your case,there are two to do it:
  1. in Site View select the elevation symbols ( both of them) and drag them outside the toposurface so that the terrain , not to be seen in section
  2. Massing and Site > click on the small arrow on the right of Model Site tab > Site Settings > Section Graphics > Elevation of poche base - choose a value to be above the maximum height of the terrain
1.
2.
Constantin Stroescu
Message 5 of 9
I wanted to say that there are two ways to do it....
Constantin Stroescu
Message 6 of 9
in reply to: constantin.stroescu
thanks fro your endeavor to help me . But in this case the elemnst below the ground line will be shown as well which I dont need to show them.
Message 7 of 9
constantin.stroescu
then , just change the earth material to a clear material (no patern)....:
Massing and Dite >Model Site >Site Settings >SectionGraphics>Section Cut Material - change the earth material to a no pattern one
Constantin Stroescu
Message 8 of 9
RDAOU
Hey @Anonymous
If it is the cut pattern which you do not want to show in the elevation; simply
  1. select Toposurface in the Elevation view
  2. Right click >> Overide Graphics per view >> by Element
  3. Under Surface Pattern >> Uncheck the Visibility Box (This removes the pattern)
  4. Under Cut Line >> Increase the Line Weight to emphasize the Ground Line (I set it to 8 in the screencast) - Note: Make sure Thin Lines mode is not ON so you can see line weights
  5. Click OK
  6. Set view to Hidden Lines and it will look as follows (See image and screencast
Message 9 of 9
Thanks but I need the earth hatch pattern for the section. Thnaks for your effort though.
Forma Design Contest
