I have an elevation and I want to show the ground line with a Ground line only and I dont need to show the earth hatch pattern like the image below. How can I do that? The one I currently have is the second image. I have tried to go VG and untick the site . I have also tried changing the cut pattern in the propoerty of the site but it did NOT work untill this point. As much as a begginer issues this may seem but there is no utorial which has covered this from my understadning.
Solved by RDAOU. Go to Solution.
YES BUT IT hides the ground line as well which I realy need. HOwever I also did try TAB to see if I just can select the hatch pattern but iut did NOT work.
In your case,there are two to do it:
1.
2.
Constantin Stroescu
I wanted to say that there are two ways to do it....
Constantin Stroescu
thanks fro your endeavor to help me . But in this case the elemnst below the ground line will be shown as well which I dont need to show them.
then , just change the earth material to a clear material (no patern)....:
Massing and Dite >Model Site >Site Settings >SectionGraphics>Section Cut Material - change the earth material to a no pattern one
Constantin Stroescu
Hey @Anonymous
If it is the cut pattern which you do not want to show in the elevation; simply
Thanks but I need the earth hatch pattern for the section. Thnaks for your effort though.
