Elevation and Command Issues
2 REPLIES 2
290 Views, 2 Replies
For some particular reason, my Revit 2015 isn't allowing me to create interior elevations and also, when opening up the program initally, it doesn'y give me the option of opening any templates and sometimes different commands won't work. I wanted to know if anyone has experienced something similar and if so, how could this problem be solved? I've tried unistalling and reinstalling numerous times, but same problem occurs.
2 REPLIES 2
arunag
Hello. Could you explain if it prompts any message while trying to create elevations or you cannot see the elevation icons.
Also while opening the template files, are template files missing or any message is flashed. please eloborate or send screenshots to understand better.
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
arunag
in reply to: arunag
It looks like your template files are missing or not in right location
check this link :
http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Also check if your templates are located correctly. refer image
Aruna
Bangalore
Forma Design Contest
