Driveway direction symbol
5 REPLIES 5
ann.tanch
1724 Views, 5 Replies
Hi, when I create driveway by floor, may I know how to set setting to create driveway direction symbol in plan view.
Thankyou for your help
Labels (2)
5 REPLIES 5
in reply to: ann.tanch
Are you talking about Driveway Direction Arrows like those found in the Site/Parking Folder of the OOTB Content Library?
....you can draw them using Detail Lines and Fill Regions directly in the Project Plan View too.
FWIW: if that herringbone-like pattern is the stripping, and is coming from a CAD Import, you could use Pick Lines Method to trace it with Revit Linework.
ann.tanch
Thank you for your suggestions, I managed to figured out a way to do it.
I created a material with the herringbone pattern and used the paint tool to apply it to driveway floor.
syman2000
The material is a great way. However how I would approach this would be to use railing. Create a small profile and then use the floor as host to get your marking. See attached
Is this just a plan drawing symbol or actual lines (e.g. paint stripes) to be installed on the ramp?
Forma Design Contest
