Hi, when I create driveway by floor, may I know how to set setting to create driveway direction symbol in plan view.
Thankyou for your help
Solved by ann.tanch. Go to Solution.
Are you talking about Driveway Direction Arrows like those found in the Site/Parking Folder of the OOTB Content Library?
....you can draw them using Detail Lines and Fill Regions directly in the Project Plan View too.
FWIW: if that herringbone-like pattern is the stripping, and is coming from a CAD Import, you could use Pick Lines Method to trace it with Revit Linework.
Thank you for your suggestions, I managed to figured out a way to do it.
I created a material with the herringbone pattern and used the paint tool to apply it to driveway floor.
The material is a great way. However how I would approach this would be to use railing. Create a small profile and then use the floor as host to get your marking. See attached
