double tee wall family
9 REPLIES 9
Message 1 of 10
apurba
2584 Views, 9 Replies
hi,
i am creating a building with 24" double tee wall by using Revit 2018.2,  everything i have found on revit accept the double tee wall.
How to select the double tee precast wall in revit ?
I have tried the sweep method but not able to made the wall type
Please help.
Apurba
9 REPLIES 9
Message 2 of 10
chrisplyler
in reply to: apurba
I suggest modeling a double-tee as an extrusion in a Curtain Panel family. Then you can create a Curtain Wall type in your project, and assign it that Curtain Panel.
Message 3 of 10
apurba
in reply to: chrisplyler
Thanks for reply.
can you please provide any training video on that
Apurba
Message 4 of 10
Alfredo_Medina
in reply to: apurba
In plan view, create a grid line or named reference plane. Then go to an elevation that is perpendicular to that reference. Then do Structure > Beam > (load or select the built-in precast double tee family), and draw the beam at an angle (not vertical). Then straighten it to be vertical. Then you might need to change the angle of the cross section if the tee comes inverted. Then copy the beam as many times as needed.
Message 5 of 10
chrisplyler
in reply to: apurba
@apurba wrote:
Thanks for reply.
Apurba
Sorry, I can't get to it today.
Subjects to look at on youtube include:
1. creating extrusions in Revit family
2. constraining forms to reference planes in Revit family
3. Revit curtain panel family construction
4. setting up Revit curtain wall type
Message 6 of 10
What curtain family did you use?
Message 7 of 10
in reply to: Alfredo_Medina
How did you get this modeled?
Message 8 of 10
sdurkee_sa
in reply to: apurba
We tried using the storefront method. Looked good by itself, but had issues with adding openings and joining to furring walls.
Our solution was to create a basic wall of three layers (concrete, insulation, concrete) and add vertical sweeps for the legs and reveals at the chamfered joints and ends.
Message 9 of 10
davidjimm
in reply to: apurba
Although this post is from 2018, I recently found it. I made the double tee curtain wall and will be happy to help others who might run across this old post like I did.
Message 10 of 10
