Double click Sheet name in Project broser
chad_arthur
Message 1 of 13
chad_arthur
I just want to tell someone that I cannot stand the new function in Revit 2019 that brings up the edit sheet name/number dialog box when I double click on a sheet in the project browser. Please change this back! I want the sheet to open when I double click it. I am okay with right clicking to open the Edit name/number dialog box. This change is driving me mad!!
Can I fix this in user settings?
Replies (12)
Message 2 of 13
Double-Click doesn't bring up the edit sheet name/number dialog box for me.
...there are double-chick CLICK options under the User Interface Tab of Options
Message 3 of 13
cbcarch
"Double-chick options" may get censored on this forum...……...Smiley Wink
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 4 of 13
Avaris.
Well, you actually did learn me something new. When you double-click slow (one second in between) the rename dialog comes up. Advice: double-click faster in order to open your sheet.
Message 5 of 13
In other words, a single click @Avaris.?   Smiley Wink
Message 6 of 13
s.borello
Hmm... it's supposed to be 1 long click... have you checked your double click options?
Message 7 of 13
Avaris.
Lol @barthbradley, it does not need to be the active sheet. But first you need to select it, when clicking on a selected sheet it will open the rename dialog. So technically it may be a double single-click 🙂
Message 8 of 13
the only different i have found is select and click brings up the rename dialog instead of rename-in-browser like previous versions. (quick) double-click works the same for me - open the sheet.
Message 9 of 13
pieterschiettecatte
You are not the only one. We warned for this during the beta and the developers luckily put in an an option to turn it off in the Revit.ini ! 🙂
More information here: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Message 10 of 13
chad_arthur
Thank you!!!
Took a minute to locate the Revit.ini file. Here is where I found it on my machine:
C:\Users\Chad\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2019
Replace Chad with your user name.
Message 11 of 13
BlakeBLarson
Changing the setting in the Revit.ini file does not change anything for me in Revit, the slow double click sheet name change still happens. This suggestion states that there is a bug when trying to change this section in the Revit.ini file. Has anyone actually had success with this? Do I need to do anything differently?
Message 12 of 13
pieterschiettecatte
There was a mistake in ini documentation. This is working for us: https://bimchapters.blogspot.com/2019/07/turning-off-double-click-rename.html
Message 13 of 13
jbrr27
This had been driving me crazy for the past couple of years!  Glad there was a solution, thank you for sharing.
