Does Revit Hardware Info show minimum or detected graphic requirements ?
1 REPLY 1
ConstantineC
133 Views, 1 Reply
On my Revit Options panel at  Hardware tab, it shows lower graphic system specs that what I actually have.
Shader 5, Direct X 11  instead of 12, and GPU Memory 4 GB instead of 8
Do these just refer to Revit minimum hardware requirements?
1 REPLY 1
DarrenP
in reply to: ConstantineC
that is just showing you your computer meets the requirements for hardware acceleration
DarrenP
Forma Design Contest
Technology Administrators
