Hi Everyone
I struggle with one specific issue. When I link a model and rotate it, all tags/annotations Doesn't follow the rotation of the model in the host... (see picture attached). Even if I select "Model orientation" in the source model.
Is there any way to align tags accordingly to the original model?
Here is the original model
And when i link and rotate it
I hope a formulate correctly my problem
Thanks a lot
Laurent
Gelöst! Gehe zur Lösung
Gelöst von LB_revit. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
