Formula for a min/max length parameter that varies depending on yes/no parameters
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
lchiossoneLCKJ2
727 Aufrufe, 6 Antworten
I'm trying to make a min/max formula that varies depending on which yes/no parameter is ticked.
I can make the min/max formula, but don't understand how to the add the yes/no parameters to it.
Basically, when standard is ticked, I want the minimum height to be 1000mm and the max to be 3000mm. And when reinforced is ticked, I want the minimum height to be 2000 and the max to be 6000mm.
Thanks!
Snips below for help
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: lchiossoneLCKJ2
Share the family here.
Nachricht 3 von 7
mhiserZFHXS
if(Standard, standard equation, reinforced equation)
Nachricht 4 von 7
lchiossoneLCKJ2
Sample family
Nachricht 5 von 7
emmanoelneri
Try this
Nachricht 6 von 7
lchiossoneLCKJ2
als Antwort auf: emmanoelneri
Thank you! This has worked! Just made some slight alterations to the min/max parameters.
Nachricht 7 von 7
emmanoelneri
Good that worked!!
But you put the solution tick in your own reply hhehehe
