Does anyone have a problem with doors families after actualising your Revitfile to 2021
10 REPLIES 10
Message 1 of 11
narea
625 Views, 10 Replies
We are having a problem after upgrading our file to Revit 2021 from Revit 2018.
The problem occurs when we select a door element, it takes at least 1 minute to show the element information. In Revit 2018 it was working without any problem, but after the upgrade all the doors have this problem. so far we don't know what can be causing this problem.
If you can give us a hint how to fix this problem, it would be awesome.
Best.
Xeo
Labels (2)
10 REPLIES 10
Message 2 of 11
in reply to: narea
Try Auditing the File upon opening.
Message 3 of 11
in reply to: narea
Share your door family here.
Message 4 of 11
narea
in reply to: barthbradley
done it. and it didnt change...
Message 5 of 11
RDAOU
in reply to: narea
@narea
Would you like to share that 2018 door family (Not upgraded) for one of us to check/test?
It is quite hard to guess what is happening and whether the issue is model related or just the family.
Message 6 of 11
narea
in reply to: narea
here you can find 2 door families. although I should send all door families, because it happens with all of them.
version 2021
Message 7 of 11
narea
in reply to: narea
Version 2018
@RDAOU
@ToanDN
Message 8 of 11
RDAOU
in reply to: narea
@narea
Tried and loaded them into project models version 2019, 2020, 2021 and 2022 ... and they all seem to work perfectly fine at my end. No odd behavior
Message 9 of 11
narea
in reply to: RDAOU
in that case, can it be a Modell Problem?
Message 10 of 11
RDAOU
in reply to: narea
@narea
Test the families on a new project...AT my end both doors seemed to have no issues with no lag in displaying their properties in the palette.
  1. It could be a model issue,
  2. it could also be a shared parameters issue (having same shared parameters of the same name loaded from different shared parameter files)
Hard to guess... wait and see how the families will behave at @ToanDN  or @barthbradley end.
Message 11 of 11
narea
in reply to: narea
thank you all for your replies. after reading your comments, i have started the whole process again. I have saved the 2018 file (Detach from Central and Audit) and then updated it to 2021. and voila, it worked.
I think it may be with the Revit version (Hotfix) or something else, who knows.
thanks to all.
Forma Design Contest
Technology Administrators
