In order to get the REVIT professional certification, do we get any sort of certification or certificate for completing for the " Preparation Course " available on the Autodesk before the actual REVIT professional certification exam.
Thanks!
Solved by yara.cp.pereira. Go to Solution.
Solved by RDAOU. Go to Solution.
@Anonymous
I do not believe there is...
what for do you need such certificate anyway?! You are neither required to present any such document to be eligible for the certification exam nor is it of any significant value for employers, for the latter, the final certification is what counts
Hi @Anonymous, yes there is.
You need to follow the entire course to its completion, and you get a certificate for completion of the Revit Prep Course Completion (the title is not entirely correct). I have mine for Revit Structure on my LinkedIn profile here: https://www.linkedin.com/in/yara-pereira-347b02176/.
You can follow the course on Autodesk University here: https://academy.autodesk.com/curriculum/cert-prep-autodesk-certified-professional-revit-structural-design
