Dimensions distorted on exported PDF sheets when using break view.
5 REPLIES 5
fik6RWB4
305 Views, 5 Replies
Hello forum, first timer post here so bear with me.
I have this strange issue where the dimension numbers on some of my exported drawings get distorted/skewed when using horizontal break. It seems a bit as if the width of the number gets proportionally skewed according to where its located in relation to the element (when I move the dimension number closer to the center of element it gets distorted more and vice versa.).
I tried different fixes such as placing the dimension only on 2D / 3D elements, moving the dimension text around, exporting in raster / vector but nothing seems to help with the issue ....
It is quite troublesome as we need to show overall height/length of elements but currently the dimension becomes unreadable ....
Any ideas?
5 REPLIES 5
Yien_Chao
in reply to: fik6RWB4
did you try with different pdf printer?
fik6RWB4
in reply to: Yien_Chao
Yes, I tried it with Adobe PDF, Bluebeam PDF and Microsoft PDF as default printer but same result. To clarify I am using Revit 2022 Export to PDF feature.
Yien_Chao
oh it is only that way with the Export option?
does the print pdf also doing this?
can you share a sample here?
fik6RWB4
It seems the issue is gone when using print as pdf.
However, I would still like to solve the issue with Export to PDF, since I have a large number of sheets and different sheets sets with naming that I need to export, for which Export to PDF works nicely.
Lachlan-JWP
Try DiRoots ProSheets (Revit add-in). It has heaps of functionality for naming and batch printing pdf's from Revit.
Forma Design Contest
