Diagonal Mesh
Diagonal Mesh
emmanuelbee
Message 1 of 15
Diagonal Mesh
emmanuelbee
Anyone got any ideas as to how i can model the attached wire mesh?, I tried to use a curtain wall by changing the angle of the mullions but that doesn't work very well, any other solutions?
Replies (14)
Message 2 of 15
Avaris.
Not modeling, but using as a texture?
Why would you increase your file-size by modeling it?
Message 3 of 15
emmanuelbee
Because texture patterns cannot be rendered
Message 4 of 15
Avaris.
Well, they are meant to be rendered. Which problem do you encounter?
Message 5 of 15
emmanuelbee
Are you talking about massing?
Message 6 of 15
Avaris.
No, I simply do not understand why you can't use this image for rendering.
Message 7 of 15
emmanuelbee
Because it won't look right
Message 8 of 15
Avaris.
What is the problem you are encountering; what does not satisfy you?
You can find higher resolution patterns on the web 'wire mesh .png'
Message 9 of 15
Why don't you use an Appearance Asset with Cutout Types? There are several in the OOTB Assets. Search "Screen".
Message 10 of 15
Don't model.  Use a material for it.
Message 11 of 15
emmanuelbee
Thanks I've just used the material for it and it actually looks quite good!
Message 12 of 15
Message 13 of 15
If you want to air and do not get in the way, please see here
Message 14 of 15
justin-brickmoon
Community Visitor
Community Visitor
Would you be willing to share this with me?  Client is asking for something simliar, but starting with this would be a HUGE time saver for us.
Message 15 of 15
tmartinez64GNQ
Hi, would you be able to elaborate on how to get this done please? I want to do a DUCT end-cap with Wiremesh/bird screen.  Thank you
