Design Builder with REVIT
Arch.m.dawood
7,401件の閲覧回数
23件の返信
メッセージ1/24
Arch.m.dawood
What the data i need to make it in revit  to be sure my analysis is correct in Design and builder
as example ( Wall , Room or Space , Floor , Celling , Posistion , orintation and thermal parameters of material )
0 件のいいね
解決済み
7,402件の閲覧回数
23件の返信
返信 (23)
メッセージ21/24
Arch.m.dawood
1- no ididn't try any software for analysis before i just try it now
because why i will depend on manual way and now there is a tecniology help me
2- yes i downaload it and i am now still in trail version i will buy it after be sure i will use it well
3- i accept soloution because it already have a good information and it help me and maybe help other but still and was need more information or details so i contunio asking
0 件のいいね
メッセージ22/24
RDAOU
Your solution is not on the Revit forum but more in DesignBuilder… however, it is important to learn how to use Revit because if you know how to use it properly you will be able to overcome 90% of the issues when transfering the model to the Energy Simulator...to cut it short
a. in the PDF I gave you 2 days ago in your other post HERE and which @ToanDN gave you again. This document describes in detail how to model each element (walls,rooms, roofs, cavities, shafts, energy settings, and more)  to ensure a proper transition from Revit Model to Energy Model and subsequently you Energy simulator. It also clarifies to to possible route you can follow (either through Revit to gbXML or through Designbuilder Plugin) You either did not read that or you have no clue how to use Revit the firstplace therefore this document made no sense to you.
b. more answers and solution you will find on the Tutorials provided by Designbuilder HERE and HERE by MIT with lots of labs and work material showing how to work with DesignBuilder and EnergyPlus and more than 100 hours of webinar footage you can watch to see how it works step by step
2- yes i downaload it and i am now still in trail version i will buy it after be sure i will use it well The trial version will not take you 25% of the way through. The software is more complicated than you imagine and not easy to operate by someone who has no background or experience in carrying out Energy Analysis calculations.
3- i accept soloution because it already have a good information and it help me and maybe help other but still and was need more information or details so i contunio asking As good as the information may be, none of the solutions you mark address the issues you are having
This will be the last reply I will post to this thread and any of your future ones. Good luck with your quest and best of luck with the guys who I am sure are  eager to help you as much as  they are eager to score kudos and solution credit.
0 件のいいね
メッセージ23/24
Arch.m.dawood
THANK YOU BRO
i know that i make you tired with a lot of question that's i ask i am so sorry
and of-course i will hope to help me in any topic i put
i know that the software it complicated and not easy to use but i will read and watch all this tutorial and pdf file
and i hope to understand more about the program
0 件のいいね
メッセージ24/24
RobDraw
All that red text hurts my brain.
Rob
0 件のいいね
