So im making a parametric balcony family, and im looking to set it up so i have a host family with the varying balcony sizes included in the sub family. can anyone talk me thorugh this?
Gelöst! Gehe zur Lösung
Gelöst von hmunsell. Gehe zur Lösung
@Anonymous wrote:can anyone talk me thorugh this?
Sure, there are many people here that can help you out.
are you referring to making Family Types? if you have a parametric family you can set up family types in that family to represent different visibility and dimensional settings. i.e. a door family can have multiple types for the different size doors it can represent.
the next time you load the family you will have the different types to select from.
Howard Munsell
Question is too generic...there 8s a help section on how to model nested families on Autodesk's Knowledge net....check the following link it is pretty much detailed on the steps to follow:
If you need more help, post your family and ask specifically where you have issues or confusion...then one may be able to help you in solving that particular issue
Or do you want to use some nested families? Perhaps elaborate on the question and possibly add some images and/or the family itself (zip)...
