Invisible elements that should be visible
Hi everyone, I'm working on a very large file at the moment with lots of links. I've assigned a view template to the 3D View but am finding that elements that are checked in the assigned view template are not showing up in the 3D. The main problem is a large floor that is invisible and I was going to apply a Decal of an aerial image to as a background to this model of a village. However the doors of a lot of linked house files have also vanished despite the fact that in the view template I've made a custom setting for every revit link and doors are checked in every link. My view is set to fine and there are no elements that are temporarily hidden. I'm wondering if because this is a very large file and I'm working on a reasonably dated computer if this might be because of my graphics card. Any help or suggestion on this would be really appreciated. Thank you
indiana_j0nes
Hi, thankyou for your query,
Could u share the screenshot please?
Check for filters, check for worksets been switched off.
You mention that its got a lot of linked files, I would check them the above in the view files too.
Cheers, k
Kunal Tuljaram Gaidhankar
ennujozlagam
have you try to uncheck your use hardware acceleration from options and see if helps. thanks
That's got it there was a rogue filter in there thanks for the help 😊
thank you
Verify that it's the view template causing the issue by creating a new default 3D view and see if the issue persists.
Could also be:
Phasing
Worksets
Design option
Filters
