Solved by Darin_HDR. Go to Solution.
I have to agree that this is a quirk of Revit that we have come to live with and work around.
In real life, when I remove a door I am left with a structured opening that I can choose to close up, leave open, or insert a new door.
In my ideal Revit, I could toggle "auto infill" (by instance) and it would make my masonry renovations exceedingly more enjoyable.
A "replace with new door" option is probably too many years out...
You really had to revive this ancient post?! AFTER 8 YEARS!!! Things one might want to consider...
Wow. Let's take it down a level.
First, the latest post on this ancient string is from 3 months ago - not that it should matter.
When I post in a community forum, I prefer to post as if I might run into this person someday and that maybe we have jobs and reputations to maintain. I am here to help and be helped. I am not asking anyone to 'Make Revit Great Again', I think it is great now and have been using it for 14+ years in which time I have not bee accused of not understanding it. Revit's greatest strength is that it is rooted in real world construction and that is actually where this string hopes to reinforce Revit's strengths
I understand your points from 1 to 3 and do not want those to change.
I disagree with your fourth assumption that I want Revit to predict what I want. What I m actually saying is that Revit is aware that it has automatically infilled an opening. The program knows where it is, how big, and what shape. So, it would be a more elegant solution for me to be able to toggle the infill off instead of creating new wall opening family for every door I want to leave open and align it.
A toggle is a choice to not have a magic wall appear where I want to leave it open. Programmers are geniuses and I know this is within their skillset, but if I don't bring up a desirable solution, it might not be at the forefront of their mind.
@Anonymouswrote:I disagree with your fourth assumption that I want Revit to predict what I want. What I m actually saying is that Revit is aware that it has automatically infilled an opening. The program knows where it is, how big, and what shape.
How is that? Im slightly confused. You agree that the cutting element is in the family and it is gone after you removed that family...and yet you expect the cut to remain with no void or insert to cut the element with?! Maybe I am missing something but it sounds somewhat like saying the opening should be an imaginary assumption.
If I am missing out on something then please explain the idea being proposed...how can do you expect to preserve the opening in a wall and if it is a toggle, what shall the toggle/switch do? A visibility toggle to make it invisible while it actually is still there ie: : make the infills invisible to make everyone happy kinda solution ... if that is the case the:
I found a work around that I think will work pretty good. If you set it up in your templete, it should get you what you want with little hassle each time moving forward.
I created a material, call it demolished opening and made it transparent. Not sure if this is necessary but I tried to make the material disappear as much as possible in the off chance it does show up somewhere by accident. Then I created a wall type (call it Demolished Opening) and made it 1/16” thick and assigned this new material to it. Again the 1/16” thickness is to make it as thin as possible in case it does show up somewhere but it shouldn’t. I assign ‘DEMO’ to the wall Type Mark.
Then I create a graphic display filter for walls with the Type Mark ‘DEMO’.
Then apply this filter to your views or view templates and make it “not visible”
Then when Revit infills the wall you demolished something out of, you select the infill wall and turn it to the Demolished Opening wall type and poof, it disappears (by which I mean every view with the filter set up in, it becomes not visible).
Check out the idea about this subject here:
http://forums.autodesk.com/t5/revit-ideas/infill-yes-or-no-option/idi-p/6473443
@Anonymous @Darin_HDR
But what @RDAOU said...holy cow you resurrected an old thread!! One with Scott Womack too...miss that guy.
E.F.D. -
Interestingly, I did do something similar on a project (but at 1/32"...).
I didn't use the filter, but that could be handy.
With historic stuff, I am probably best served by editing the wall profile if I don't need it to be smart in other areas.
