Hello people,
I am having an issue here with an existing roof which we want to demolish partially to create a new dormer. I have attached 3 pictures showing existing, demolished and proposed.
So I tried the dormer command and "Pick Roof / Wall edges " but I get this error:
"Dormer Opening Cut is not fully defined. Cut was not performed."
Tried cut by face and vertical and I think it will cut through the existing roof in the existing phase rather than demolishing a part of the roof in the new construction phase. I suspect that because I get an error also that the Rooflight is losing its host.
So I guess my question is:
- can I demolish a part only of an existing roof in new construction ? also it would be nice if it could infill automatically the bit on the left hand side where the old dormer was - similar to what walls do when you demolish a window.
or
- do I have to demolish the whole roof, build a new one which only has an opening for the new dormer ?
Cheers.
Solved by RDAOU. Go to Solution.
Why don't you not use the Dormer Tool at all, and just model the Dormer infill portion as an independent and phased Roof?
As it is now in the images you posted, it works as follows
Those (Vertical Opening Cut, Opening by Face, Dormer, Wall Opening) are geometry modifier tools, they are not phase-able. You can do one of the following:
- create a family or in-place family with a void or an opening under New phase and cut geometry the existing roof with this family (while you are in the family editing environment)
- Split the existing roof into two and demolish one
