@Anonymous
Not sure if this is what you are looking for
- Either add the results in the default parameters that come with the wall family such as "comment";
- OR add a new project parameter (say Test Results) and under categories assign it to walls(Instance; text type I would assume)
Go to View > Create > Schedules > Schedules/Quantities and create a wall schedule (the new project parameters should be available as a new field...add it to the schedule and input the test results in it...
![Project Parameter.png Project Parameter.png](https://forums.autodesk.com/t5/image/serverpage/image-id/236421i0F4BD9A833FE6472/image-size/original?v=v2&px=-1)
If you are using Revit 2017 you might want to try global parameters for a change
