database
1 REPLY 1
144 Views, 1 Reply
database
I made some concrete strength tests of a wall. I want to add this information in the model and then to read in a database. how should I do? I have no idea.
Ieda
1 REPLY 1
RDAOU
@Anonymous
Not sure if this is what you are looking for
  1. Either add the results in the default parameters  that come with the wall family such as "comment";
  2. OR add a new project parameter (say Test Results) and under categories assign it to walls(Instance; text type I would assume)
Go to View > Create > Schedules > Schedules/Quantities and create a wall schedule (the new project parameters should be available as a new field...add it to the schedule and input the test results in it...
If you are using Revit 2017 you might want to try global parameters for a change
Forma Design Contest
