Custom stair handrail
4 REPLIES 4
mahanmotamedi1991
314 Views, 4 Replies
Hello Everyone,
I want to make a custom handrail for a stair in Revit. I want to make a handrail like an image 2 from what I have in Image 1. Can someone guide me on how to do it?
All the best,
Mahan
4 REPLIES 4
RDAOU
in reply to: mahanmotamedi1991
@mahanmotamedi1991
Edit the Rail Path
  1. Set Slope to Flat
  2. Set Height Correction to Custom - Enter Correction value as necessary
mahanmotamedi1991
in reply to: RDAOU
Thank you very much for your response. Could you please explain to me how you could trim the handrails on the top of each stair step?
Best,
RDAOU
@mahanmotamedi1991
  1. Pick new Host and Host it on the stairs...
  2. If that doesn't work, Edit path and make sure it is aligned to stair Edge. Finish Sketch
  3. PS: If you need to offset the rail, Select it and on the properties palette add a value to "Offset from Path"
Thank you very much
Forma Design Contest
Technology Administrators
