Curtain Wall Panel problem with the array
Hallo everyone! I have modeled a generic face based family (with other nested ones in it) with a length type parameter that rules the array number of the connections (one of those nested families)
Then I nested it in a Curtain Wall Panel family, linking the length type parameter of the nested family with an instance reporting parameter of the length of the Curtain Wall Panel family
I have checked that adjusting the length of the panel both the array and the nested family run correctly.
At this point I have tried to use that panel inside of a custom curtain wall (in a new project) but then I have faced out that something wrong happens between the nested families of the very first generic face based family.... I don't understand what's going on.. can you help me please?
I have attached two families:
- FFA_beam is the generic face based family
- FFA_panel_mittelprofil is the Curtain Wall Panel family
Unfortunately I were not able to attach the Project, but this is the easiest thing to do: to test it, as you know, you should load the Curtain Wall Panel family into a new project and modify the default Curtain Wall system family, putting the new panel into it, with a vertical grid fixed spacing equal to the number after 45/"..." which is the width of each family type.
Thank you!
