Curtain Wall Mullions Subcatergory
4 REPLIES 4
748 Views, 4 Replies
Is there any way to set curtain wall mullions types to an object style subcategory?
4 REPLIES 4
Go to Object Styles, and create another catagory under curtainwall mullions. Then you should be able to set the mullions to this.
But how do you assign a mullion type to different subcategories? There isn't a subcategory parameter available in the “family: mullion” properties, nor is set in the curtain wall or the mullion profiles.
What I need to do is export different mullions types onto different layers and the only way I can find is to create the mullions within a curtain wall panel and assign them as different subcategory of a panel.
Is this ever solved?
For exporting i want to know this too. I want my glass panels to be on a different layer then the closed panels.
Also for railings, i want my glass on a different layer when exporting.
hmmm... curtain panels already solved, i had to make a new panel type, not use the system ones....
Forma Design Contest
