Curtain Wall Height Dimension not as Properties
5 REPLIES 5
IMCornish
693 Views, 5 Replies
I have inserted a curtain wall into a stacked wall and used the 'cut' tool to subtract it from the masonry.  However, whilst the properties for the curtain wall show the correct placement and dimensions, the height is greater than the wall it is inserted into when it should be lower.  The curtain wall when looked at in elevation only has 3 Shape Handles, being to the left and right and at the base but none at the head.  Further when looked at in section, whilst the dotted cross lines, demarking the top and bottom of the curtain wall, are in the correct place, the vertical centre line extends up past where I wish the height to be!
I have been using Revit since 2009 and never encountered this problem before. I am now using Revit 2021 and getting increasingly frustrated so can anyone help please?
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
Labels (3)
5 REPLIES 5
_Vijay
in reply to: IMCornish
Can you show some images with your intension for better clarification.
IMCornish
in reply to: _Vijay
Here are some images, hopefully they will be explained by my initial post.
Thanks for your help Vijay
Andrew Robertson
Chartered Architect
Truro. UK
Try to detach it. Probably was previusly attached to roof or reference plane
Thank you very much, you solved it.  Don't know how it got attached but I am really grateful.
Andrew Robertson
Chartered Architect
Truro. UK
Glad it helped!
Forma Design Contest
Technology Administrators
