curtain panel with tringle pattren
9 REPLIES 9
Message 1 of 10
tu4050955
462 Views, 9 Replies
Hi
i made this by curtain panel pattren based (tringle flat)
when i upload the mass it came like this
it supposed to be like file 2
and mine in file 1
i try to do it on circle and didn't change
9 REPLIES 9
Message 2 of 10
in reply to: tu4050955
Your form may not be constrained properly to the adaptive point(s).  Drag each adaptive point in the family and see if the form follow.
Message 3 of 10
Post the Family.
Message 4 of 10
tu4050955
in reply to: ToanDN
I did it and it follow the form so there's no problem with it
 one is working fine and the other next to it is not
Message 5 of 10
tu4050955
in reply to: barthbradley
here is the family
Message 6 of 10
Nothing is constrained in the Family.
Change the size of the Horizontal and Vertical Spacing and you'll see it blow up in real time.
Message 7 of 10
tu4050955
bigger or smaller?
Message 8 of 10
The three corners are okay but the top point of the family is not.
Message 9 of 10
See attached. I think you can figure it out what I did. Basically, your z Ref. Point has lost its driver.
Message 10 of 10
tu4050955
Thank you so much
Forma Design Contest
Technology Administrators
