Hi
i made this by curtain panel pattren based (tringle flat)
when i upload the mass it came like this
it supposed to be like file 2
and mine in file 1
i try to do it on circle and didn't change
Solved by barthbradley. Go to Solution.
Your form may not be constrained properly to the adaptive point(s). Drag each adaptive point in the family and see if the form follow.
I did it and it follow the form so there's no problem with it
one is working fine and the other next to it is not
Nothing is constrained in the Family.
Change the size of the Horizontal and Vertical Spacing and you'll see it blow up in real time.
See attached. I think you can figure it out what I did. Basically, your z Ref. Point has lost its driver.
