Creating a custom fill pattern Revit 2015
5 ANTWORTEN 5
Nachricht 1 von 6
johanas007
2170 Aufrufe, 5 Antworten
Hello!
I am trying to create a custom fill pattern for my floor tile. I have read up on how to create custom .pat with Notepad and text, but my tile is coming in all wrong.
Can someone give me a cheat code and tell me what I should type in text code  in order to create a .pat 6" x 35" tile with a 1/3 offset?
I attached a picture for reference.
Thanks!
5 ANTWORTEN 5
Nachricht 2 von 6
cbcarch
als Antwort auf: johanas007
Check out Hatch22 from Mertens3d. It used to be free, but now costs about $45 I think.
Works really well--runs inside Revit. Install is a bit tricky, but well documented / instructions.
You draw lines in a drafting view for your custom hatch pattern, select them, open the add-in and it creates the .pat file from the selection.
Then save the .pat file, and create your custom fill pattern.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 6
hugha
The attached pattern was generated by the Brick & Tile Wizard contained in HatchKit 2014 for Revit - as shown in the attached screenshot.
You can try HatchKit 2014 for Revit Demonstration Version by downloading from here:
http://www.hatchkit.com.au/download.php
hth,
Hugh Adamson
www.hatchkit.com.au
Nachricht 4 von 6
als Antwort auf: hugha
In this example, what do all these numbers mean?
How would you change the dimensions of the tiles?
Nachricht 5 von 6
als Antwort auf: Anonymous
Nachricht 6 von 6
hugha
The numbers are explained in the preamble to the standard text file revit.pat or here:
This blogpost gives a very good overview of how a stretcher bond brick pattern can be defined.
PAT files are text so can be created with a text editor or with the assistance of a fill pattern editor.
hth,
Hugh
