CORRUGATED ROOFING!
CORRUGATED ROOFING!
CORRUGATED ROOFING!
I have made a corrugated roof/cladding system using a beam system. it works like cladding, after you create a roof you can simply choose the area of the roof you want to be corrugated as your work plane and the beam system will appear as 1200mm panels of corrugated cladding. works in ALL views. took me a while to find out how to make it so i thought id save other people the time.
sakar_deepak
@Anonymous
Will it work on rectangular/ circular sloped roof too sloping on all sides ? Could you explain how to use it step by step ?
Regards
Deepak Gupta
Architect
(...... those, who are answering the problems in community forum here, are great people .....)
I havent used it on a conical shaped roof as of yet, i dont think Revit
will like it much as they are beams not an actual rooftype, you may end up
with lots of overlapping edges. the way i use it on a mono or dual pitch
roof is in 1200 centre beams along the same plane as the roof, this gives a
seamless corrugated panel over the whole span of that part of the roof.
(with is not a fully working roof type its a quick fix, its actually a beam
system)
Sahay_R
Just tried it. Works like a charm. Thanks @Anonymous!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Happy to help 🙂
Great work!  Corrugation is a tricky thing to accomplish in Revit!
