Hi fellas!
I have a weird problem where a copy of a dwg from the key plan appears from nowhere. I can't find the copy in the family.
Does anyone have a solution?
I've attached the file.
Solved by sara. Go to Solution.
Found it using Ideate Explorer. Deleted and attached.
Hi again fellas!
A new problem just showed itself. I get a similar problem where a frame shows up out of nowhere.
Would appreciate all help I can get with this one. Such weird problems!
Nevermind. I found that the layer "DEFPOINTS" from AutoCAD was messing it up. Re-imported the dwg.
Strange though that it doesn't show inside the family but shows when plotted?
